Dave's RV-10 Build Log
Date:  2-6-2019
Number of Hours:  3.75
Brief Description:  FWF A/C Hoses Installation
Reviewed preliminary left A/C hose routing from the firewall to the compressor. Decided to adjust the routing to better fit around the muffler, which required moving the Adel cushion clamps on the engine mount. After getting the firewall end satisfactory, crimped the 45 deg. hose end to the hose. Then adjusted the front of engine cushion clamp installed for this to take up slack in the hose and get the hose direction right. Once that was satisfactory, cut the hose to length and crimped the 90 degree hose end to the hose. Did not connect the hose to the compressor at this time, in order to avoid breaking the compressor connection seals. Hose ends are temporarily held near the compressor connections with tie wraps.
Repeated the above for the right side A/C hose from the firewall to the compressor.
A/C Hose @ Firewall
A/C Hose @ Firewall
A/C Hose Under Cylinders
A/C Hose to Compressor
