Removed clecoes and duct tape from compressor bump out. Sanded the edges of the bump out and roughed up the rest of the bump out. Placed 1" fiberglass tape around the edges of the bump out and then bonded with thin epoxy/micro. Then applied a thin coat of the same epoxy/micro to the rest of the fiberglass bump out.
Installed the sway braces to both exhaust mufflers to complete the exhaust system.
Sanded down the epoxy applied to the oil door to fill the oversized holes due to rivet problems. Taped the door to the cowl and then re-drilled the holes in the door to match the hidden hinge holes. Determined that it will be best to attach the oil door to the hinge using 632 flat head screws MS24693S29 with nylon lock nuts AN364-632 and ?AN960-6 washers, rather than rivets. Will have to order this hardware and don't have it on hand.
Installed extra wires (3 ea. #16 and 1 #20) for the right side seat heater.
