Began cutting and installing the baffle seal fabric onto the aluminum baffles.
Using McFarlane Cowl Saver Baffle Seal Material, Continuous 3" wide, scored for the sides and rear baffles. Had this left over from replacing the seal fabric on my Grumman Traveler a few years ago, and it is more flexible and in theory should provide a better seal than the Van's standard material.
Also started making yet another cross piece to fit over the prop governor and tie the two sides of the baffle together.
