Worked further on the left inlet ramp baffles. Cut the forward baffle further until it fit. Created an angle bracket out of .065" aluminum to attach the CB-1001A front baffle to the top rear mounting bolt for the prop governor.
Created a cross piece of aluminum that wraps over the top of the governor to stiffen and help close the front left baffle and attaches with nut plates and screws.
Rotated the governor control head to align with the control cable bracket for top control cable routing, then re-installed the cable bracket.
