Brief Description: A/C Compressor Installation Started
Removed the left inlet ramp baffle which is in the way of the compressor.
Installed the stud bolts for the compressor into the mounting pad on the engine block just below the prop governor.
Installed the compressor mounting block to the engine block with 3 spacer shims between the mount and the engine block. Did an initial trial fit of the compressor to the engine and had questions regarding the mounting and hardware provided, as the drawing provided was not up-to-date showing the new wide grooved serpentine belt.
