Dave's RV-10 Build Log
Date:  11-29-2017
Number of Hours:  3.50
Brief Description:  Door Switch Wiring
Installed shielded twisted pair wire between the back of each door and the front of each door in existing conduit.
Soldered the wires from the rear proximity switches to the twisted pair wires and sealed each connection with heat shrink sleeve. Labeled these wires as Door-Left-Rear and Door-Right-Rear.
Installed a coil of shielded twisted pair wire from the front of each door to be connected to the G3X system for door alarming. Labeled these wires as Door-Left and Door-Right.
Connected the shields between the Rear wires and the front wires with a short green 22 AWG soldered drain wire. Connected the white wires together by soldering. Connected the front door switch to each of the blue wires by soldering, so that the 2 door switches are in series on each side. Sealed the front connections with heat shrink tubing.
Bundled the wires at each of the door switches with spiral wrap for protection and neatness.
