Dave's RV-10 Build Log
Date:  10-31-2017
Number of Hours:  4.75
Brief Description:  Nose Gear Fairing
Printed the template at Office Depot to the correct full size.
Cut the nose gear fairing using the template and construction drawings. Fitting the lower end of the fairing to the wheel fairing took about 8-10 trials and additional trims until it fit properly to the wheel fairing.
Cut the fairing hinge to length. Marked the centerline for the rivets on the hinge outside.
Layed out the rivet holes for the fairing hinge onto the fiberglass fairing.
Stopped work early to go home and prepare for halloween trick or treaters.
