Sanded the entire inside surface of both doors with 100 grit to break the gloss and provide tooth for the paint to stick.
Applied 2 coats of UV Smooth Prime to the inside surface of both doors. Let the first coat dry while having lunch and then applied the second coat. Used a 6" foam roller and a corner/touchup pad to apply the primer, rather than spraying. Will spray the paint coats however.
