Brief Description: Hang Door & Trim Door Window Plexiglass
Installed the right door to the cabin top. This door also fit properly without the need for any shims.
Removed both doors from the hinges. (Left the hinges attached to the cabin top.)
Trimmed the plexiglass window to fit the left door opening. Used the Dremel tool with HF diamond cutting disks to do the initial cuts. Then did final fitting with a combination of a fine grit Perma Grit Sanding Block and 80 grit sand paper on a 12 inch 2x4 to straighten the sides. Once the window fit the opening properly, then used a scraper to finish all the edges and round the edges to prevent stress points and possible future cracks.
Started the initial trim of the right plexiglass door window.
