Dave's RV-10 Build Log
Date:  6-23-2017
Number of Hours:  2.50
Brief Description:  Bonded Doors Together
Bonded the two sides of each door together.
Used West System Epoxy with slow hardener. For each door:
- Used 4 pumps for the straight epoxy to wet out the ParaBeam and cover the door cavity bonding surfaces.
- Used 9 pumps for the Cab-O-Sil mix used on the outer flanges and window flanges.
After using clecos to attach the door halfs to the fuselage, used lots of duct tape to securely fasten the door to the fuselage and cabin top and hold it in place while the epoxy cures.
With Kristi's help and advance planning, we were able to complete each door from the initial epoxy mix to fully fastened in a bit less than 30 minutes.
