Installed the Center Cabin Brace that supports the front top of the fiberglass cabin top.
Cleaned up the epoxy from around the door openings. I should have removed the masking tape I used to protect the aluminum door areas before the epoxy fully set up, as it was difficult to remove with the epoxy fully cured.
Prepared the doors for gluing by sanding the areas to be glued with 80 grit using the random orbit sander. Masked off the cabin top to protect it from epoxy during the door gluing. Cut the 3 dimensional weave glass fiber fabric ParaBeam per the plans to be used in the elbow and cranial cavities.
