Brief Description: Final Prep for Cabin Top Attachment
Did final preparation for the permanent installation of the cabin top.
Installed the matching connector (just received yesterday) for the air conditioner blower motor to the wires previously run from the front, connecting the blower.
Installed the 2 wires running from the baggage overhead light (in the overhead console) to the light switch location in the baggage bulkhead cover near the baggage door.
Crimped the connectors onto the #2 AWG cable from the master relay to the starter relay and connected the cable to each relay's main terminal. Connected the 2 cables for the battery connection to the master relay and the ground connection near the battery holder. Connected the master relay control wire to the relay.
Cleaned up wire bundles in the tail cone, secured them with tie-wraps to the anchors previously installed and laced wires to further bundle them. Installed spiral wrap around a couple of bundles to protect them from possible contact with tail cone components.
Removed all the masking from painting the cabin top. I believe I am now ready to permanently install the cabin top.
