Applied an additional coat of paint the the inside of the fiberglass canopy.
The prior coat was inconsistent due to paint thickness being variable. Sanded down with Scotch Brite red pad in prep for another coat.
Added 5% water by volume to the paint to thin it for better spraying. (500 ml paint, 25ml water) Set air pressure higher to 70 psi at the hose connection to the syphon spray gun. This combination seemed to improve the spray considerably and made for a thicker, more consistent spray coat.
