Dave's RV-10 Build Log
Date:  3-29-2017
Number of Hours:  6.25
Brief Description:  Installed Coax Antenna Connectors, Rung Out Wires
Installed BNC crimp connectors to the end of coax cables in the tail cone for antenna attachment. Also installed the TNC crimp connector to the coax for attachment to the XM antenna.
Rang out the avionics wires run from the tail cone to the front panel using an ohm meter and color coding applied to wires when cutting them for installation. Labeled the wires with clear heat shrink over hand written labels, since these labels will be replaced with printed labels when the wires are terminated.
