Dave's RV-10 Build Log
Date:  3-28-2017
Number of Hours:  7.00
Brief Description:  Fiberglass Added R. Wingtip; Installed R. Seat Flo
Removed the left wing tip that was clecoed to the wing while the fiberglass added prior day cured. The additional layer of glass tape helped stiffen the wing tip.
Installed a layer of fiberglass to the inside of the right wing tip using 4 in. fiberglass tape and epoxy (no fillers). Installed the wing tip onto the wing to allow the epoxy to cure with the tip held in place by clecos.
Installed the right side conduits into the right rear seat floor cover. Riveted the floor back in place per the drawings. Installed the A/C hose connection access cover plates into both rear seat floors.
