Labeled both ends of the wires installed that run from the panel to mid fuselage and from mid fuselage to the tail cone. Used the wire labels printed yesterday along with clear heat shrink tubing. Determined the wires by ringing them out one by one with an ohm meter.
Installed molex connectors on wiring connections to the flaps and the fuel boost pump. Used the Molex 2.36mm Diameter Standard .093" Pin and Socket Receptacle Housings and associated molex pins suited to the wire sizes used on these devices.
