Ran the wires to the fuel boost pump per the OP-37 instructions, through the cushion clamps previously installed. Had to upside the clamps to hold both wires. Ran wires to the right side of the tunnel about mid-seat for the righ front seat heater. Used small plastic electrical tubing to protect the wires, with spiral wrap at the location above the tubing.
Ran wires to the flap motor per the OP-37 drawings, using the cushion clamp called out in the drawings.
Ran wires to the terminal block mounted on the left front face below the rear seat, in the area above the flap torque tube, using the cushion clamps called out in the OP-37 drawings, plus the addition of 2 tie-wrap pads riveted into place with LP4-3 rivets.
Determined a location for a grounding bolt and drilled/installed the bolt with 4 wires appropriately sized attached with ring terminals.
Routed the Nav/Strobe and Taxi/Landing light wires previously installed from the panel location to the terminal strip, and terminated each one with a ring terminal on the appropriate terminal as layed out in my wiring sketch.
Realized about half way through the terminations that I had not labeled the wires. Will have to add labels to these wires later.
