Brief Description: Cabin Top Finish & Avionics Planning
Sanded the UV Smooth Prime finish applied to the cabin top yesterday. This did a nice job for most of the cabin top, but there are still some areas that were originally very rough that are still rough. Not sure if I should work these with epoxy/micro, or just paint as-is.
Reviewed the wiring requirements for the G3X components to figure out what wiring is required outside of the panel that I should install now. Still have questions.
Reviewed the drawing for the wing tip attachment but not clear on the trimming instructions. Will call Van's Builder Assist.
