Brief Description: Installed Power Wiring - Tailcone to Rear Seats
Confirmed the wiring required to run from the tail cone to the area in front of the rear seats. Cut the wires required. Trimmed the conduit for this wire run, and pulled the wires into the conduit. Determined that I had not cut the #16 AWG wires long enough and so had to remove all the wires run in the conduit, cut longer #16 wires, and then re-pull the wires back into the conduit.
Secured the conduit in the tail cone with zip ties in #28 holes drilled in the J-stiffener.
