Dave's RV-10 Build Log
Date:  2-19-2017
Number of Hours:  1.00
Brief Description:  A/C Hose Guides & Drain Fitting
Riveted a hose guide bracket on each side of the fuselage low and forward inside so that the A/C hoses running to the firewall are kept out of the way of the rudder pedals.
Applied Pro-Seal to the mounting flange of the A/C drain fitting going through the bottom of the tail cone and riveted in place with 4 rivets. The soft aluminum of the flange made riveting this a little more challenging than usual.
Kristi helped drive all of these rivets since I couldn't reach both sides by myself.
