Brief Description: Cabin Top Vertical Support Post
Installed the powder coated vertical support between the cabin top and the panel glare screen, using 2 shims made from 0.035" aluminum scrap. Match drilled the holes into the fiberglass cabin top, then into the support angle in the panel support structure.
