Brief Description: Rivet Fuel Flow Transmitter Bracket to Fuselage
Removed the FT-60 flow transmitter and bracket from the tunnel where it was clecoed in place with tubing installed hand tight.
Filled the original holes in the fuselage for the flow transmitter with AN426 3-3 rivets.
Dimpled the new holes previously drilled using the close quarters dimpling tool that uses the pop rivet puller to pull the dimple dies. Drove new rivets AN426 3-4 from the bottom of the fuselage to fasten the flow transmitter bracket. (Kristi drove the rivets from below while I bucked them from inside the fuselage.
