Brief Description: Installed the Fuel Flow Transmitter
With the bracket for the flow transmitter riveted in place, I re-installed the FT-60 (red cube) onto the bracket, and then re-installed the previously fabricated tubing connecting the transmitter to the fuel pump discharge and the tubing from the transmitter outlet to the firewall fitting. Tightened/torqued the tube fittings.
