Brief Description: Flap Bushings; Cowl Attach Hinge Fabrication
Fabricated the 4 UHMW flap bushings per drawings, including the optional trim.
Fabricated spacers and drilled the flap motor hole for safety wire. Did not install the flap actuator as want to wait until control system push rods are installed first.
Fabricated the cowl attach hinges and shims. Did not install them as need to wait until the control panel assembly is installed. (Initially created duplicate rather than mirror image hinges. Had to re-make some and cut down wrong ones to make shorter ones. Managed to complete all with the supplied hinge materials.)
