Installed the standard Van's fuel selector valve in the fuselage. Not sure how this valve and location will work with the Aerosport center console that I intend to use.
Fabricated fuel lines from the fuel valve to the bulkhead fittings in the tunnel, and then from the bulkhead fittings our the side skins for connection to the wings.
Ordered the fuel pump and filter from Van's today, and will complete that portion of the fuel system once I receive it.
Separated the rudder brake peddle parts and de-burred them with the Scotchbrite wheel on the grinder.
