Completed initial mating of tail cone to fuselage. Adjusted locations of bulkhead, stiffeners, etc. so that all elements were in the proper location, with clecos to hold all sections securely together.
Drilled holes in longerons and installed 4 bolts in each for connection
Match drilled all holes and performed machine counter sink on those indicated by plans.
Next step at end day is to disassemble tail cone from fuselage at next work session.
