Dave's RV-10 Build Log
Date:  8-1-2016
Number of Hours:  7.50
Brief Description:  Pitot Mast
Installed pitot mast into wing bottom skin
- Cut out hole for mast using step drill and saber saw. Cleaned up and final size with Dremmel tool using sanding drum and small grinding wheel.
Ran tubing for pitot and AOA in left wing along J-stiffener
Installed nut plates and reinforcing ring in baggage floor for step bolt access plate
Prepared aileron actuator tube and new alum. parts for primer.
Pitot Mast
Pitot Mast
