Completed fabrication of the bell crank to aileron push rods. Cut steel tube to form Torque Tube Collar WD-1014C, and installed to create the Torque Tube Assemblies for the right and left sides. Now need to prime the tubes.
Added epoxy resin to horiz. & vert. stabilizer tip fairings to smooth them.
Ran brake lines from fire wall to bulk head fitting. Had problems getting screw started in nut plate after reversing the cushion clamp to route the lines under the hole for the fuel line.
