Used saber saw to cut out the access panel opening for the right side in the baggage compartment floor. Used Dremmel tool and files to finish the cut and smooth it to proper size. Assembled the nut plates to the reinforcement ring, and then installed the ring into the floor with AN426 rivets.
Layed out and cut the access panel opening on the left side baggage floor panel, in the same way as the right hand opening. Have to order addtiional nut plates for the left side access plate before completing this panel.
Spent the afternoon preparing most of the provided parts for priming, using red Scotch Brite pads.
