Mixed primer in order to prime a few fuselage parts. Initially tried spraying with a large HVLP sprayer from Harbor Freight, however this sprayer clogged almost immeidately and could not be used. Broke out a new smaller HVLP sprayer in the same Harbor Freight kit, and was able to use it to apply the primer, however it too functioned poorly and resulted in a thicker coating that I wanted. Primer dried almost immediately due to very hot weather.
Started planning for location of access panels to allow access to the bolts that hold the steps in place. (There are many people on VAF who have had to access these bolts due to loose steps after a couple hundred hours, and found access nearly impossible.) After doing a first layout, I discovered that a side trim panel in the baggage compartment would interfere with the hatch, so had to start over on the layout. Eventually decided to use the access plates provided for the stall warning switch, and install them as close to the side trim panels as possible. Did the layout, and cut the panel opening corner holes.
