Brief Description: Continued QB Fuselage Review Against Plans
Added a second fiberglass layer inside of each of the 3 empennage fairing tips and clecoed back into place to cure.
Continued to work through each of the steps in the drawings to verify work completed by QB team. Need to determine type of fuel flow meter to be used (Flo-Scan or FT-60), in order to install the proper nut plates in the Flo-Scan mounting bracket, and then rivet the bracket to the bottom skin. (Currently installed to skin with soft pop rivets.)
Cut out the specified portion on F-1057 Left & Right mid seat rail support brackets. Will need to prime brackets before riveting them together (4 brackets total). Will purchase primer from local Sherwin Williams store in Stafford, TX (P60G2 Wash Primer and R7K44 Catalyst Reducer) during the weekend.
Drilled front seat cover plate mounting holes to size per plans. Misunderstood plan requirements to fabricate seat cover plate angle stiffeners and built the 2 stiffeners, then determined that these had already been fabricated by the QB team and riveted to the cover outer rings.
Drilled out a number of soft pop rivets from fuselage cover plates. Also drilled out the temporary rivets holding to fuselage front top control panel assembly in place, but kept it in place with clecos.
