Filed elevator up stop to increase travel to the 30 deg. specified. Created brackets for trim bellcrank brackets and trim cable anchor brackets. (Had problems with locating holes in one of the bell crank brackets, and had to re-make the bracket twice.) Riveted all components to trim mount bracket assembly Assembled trim servo link and mounted to trim servo. Installed trim servo to bracket assembly and connected servo link to bell crank.
