Dave's RV-10 Build Log
Date:  6-25-2016
Number of Hours:  6.50
Brief Description:  Elevator Push Rod & Rudder Install
Fabricated elevator push rod, installed and adjusted per drawings.
Filed elevator stop to achieve range specified. (Used iPhone to accurately determine stop angles.)
Installed Rudder to Vertical Stabilizer and adjusted bearings to reduce rudder travel between stops to 37 deg. each way.
Removed Elevator and Vertical Stabilizer.
