Dave's RV-10 Build Log
Date:  3-4-2016
Number of Hours:  4.00
Brief Description:  Complete Vertical Stabilizer
Completed vertical stabilizer build
- Complete fabrication/riveting of rear spar assembly
- Allemle fron spar and ribs to rear spar, forming skeleton assembly
- Dimple skin
- Insert skeleton into skin and rivet skin to skeleton. Bucked interior rivets & squeezed edge rivets using pneumatic squeezer.
- Damaged a few rivets on the edge due to close edges of spar caps and doubler. Drilled out bad rivets and re-riveted using modified squeezer des. (Ground down one side of die to allow for fit into the tight space.)
Rivet skin to skeleton
Completed riveting
Completed riveting
Completed Vert. Stab.
