Dave's RV-10 Build Log
Date:  3-1-2016
Number of Hours:  8.17
Brief Description:  Elevator - Day 1
Separate stiffeners using snips, clean up & debur with Scotch Brite wheel
Dimple skins, top & bottom for both elevators
Assemble spars (by Jake)
Rack rivet stiffeners to skins. (Bent over 8 rivest, drilled out & re-riveted)
Rivet clips to spars
Cut trailing edge aluminum wedges to length, debur, score with 60 grit sandpaper for glue.
Fit skins & spars together, match drill holes, disassemble, debur. Enlarge stiffener holes using #30 mill.
Reassemble skins & spars, rivet using custom long bucking bar
Connect top & bottom stiffeners using blind rivets.
