Brief Description: On the road all day getting the panel cut,fetching
Was informed by the cutter in johb that the panel could not be cut on their machine because of the flange bent in since the spindle bit had no clearance. Laser cutting was suggested but I did not like the idea of super heating the thin metal with very delicate framework with the cutouts, contact with builders on avcom confirmed that lasers were a bad idea.So drove to Johannesburg to fetch the panel then back to Centurion (Gateway park) to my original cutter who looked at it and made the necessary adjustments to his machine to make the cut. left the panel with him to be collected the next day.
