RV-7A Tip-up QB build project
Date:  9-11-2012
Number of Hours:  7.00
Brief Description:  ...continued finishing of fiberglass - V-stab plat
Continued sanding, shaping, filling, spotting, finishing and priming of all empennage tips, repeated until a smooth and flush finish results
Also final drilled all V-stab base holes for empennage fairing attachment and installed all platenuts, checked against the fairing for fit as per Stab process. Fairing holes adjusted/moved to better fit the pattern drilled into the stab. Old holes on fairing will be filled.
Also spent 1.5 hours out getting supplies.
