Brief Description: Supplies, Finalized the compass tray,
Spent m ost of the morning - first half of the day out and getting supplies, came back to finalize the remote compass (SP6) unit and did so by installing the rivets and trimming and made up a bracket to secure it to the bulkhead.
Also saftied and secured all fixtures of the stick assembly to pushrods etc- essentially finalized the assembly and saftied all bolts.
Found an issue with the pitch servo actuator rod which I messed up and had to remove to redo. I had drilled the rod ends in the tubes but failed to realize that the actual eye bolts screwed out the ends and destroyed the eye bolts - a stupid mistake but easily made when considering the type of rod end fixture Van's uses.
