Spent most of the day painting, all the silver bits (the last of the interior paintwork) for the canopy, canopy frame, skins, latches etc that had to be silver were finalised and give the last coats or all their coats, some parts that were previously finalised were touched up.
Also spent some time on the canopy frame to deck fitting where I had noticed the frame not coming out of it's hinge blocks easily at all, I found that the pins werent pulling out completely and needed some adjustment, I opened up the hole in the subpanel to allow mopre clearnace and filed away some of the arm to allow even more travel in the swing which worked eventually.
Also trimmed the sub panel flanges per the instructions to allow the frame to swing up and down without scraping.
