RV-7A Tip-up QB build project
Date:  1-20-2012
Number of Hours:  9.50
Brief Description:  Final seraled up the firewall and recess and...
Complete firewall sealed, both sides, top, bottom and all joins - all clamped and cleco'd overnight (but actually left for 48hrs). Put in the final bolts for the stick assembly and assembled the small pushrod to the large pushrod and to the bellcrank. Some more stripping work done on the exterior, the firewall and the cabin interior - holes, covers etc all masking stripped with the time consuming process of applying paint stripper to soak then heating up a home-made blunt scraper tool and then scraping away the masking and glue and then rubbing vigourosly the left behind glue and marks and then rubbing with scothbrite, any scratches.
