RV-7A Tip-up QB build project
Date:  1-18-2012
Number of Hours:  9.00
Brief Description:  Removed and cleaned and replaced major assemblies
Removed and cleaned and replaced major assemblies in the cabin and rear fuz, more tape stripping and fuel lines removed and templates made for new lines. With paint stripper and thinners in hand stripped and cleaned the firewall mating surfaces and mixed up compound to glue up the right side of the firewall assembly and the firewall recess bonded in place and holes sealed up.
Having removed the stick assembly I cleaned then re assembled per instructions for the final assembly and installation into the cabin floor.
final installed bellcrank bolts and assembly.
