RV-7A Tip-up QB build project
Date:  11-3-2011
Number of Hours:  9.50
Brief Description:  Fwd deck continued, panel layout research, fuel li
Continued assembly of forward deck and tip-up structure and fabrication of further parts for the mechanism. Dry fitted and other parts final fitted. Forward deck now 80% complete with some final parts fabrication and riveting of all available parts. Removal of lines and prep of the area and holes and mountings of the fuel lines to be replaced completely.More time spen on panel layout options with the mockup and panel drawings used to work out a final panel layout. More research done into the avionics choices with consultation on avcom and with Rainier of MGL.
