Brief Description: More struggle with screws and asembly of front dec
More drama trying to remove the offending #10 screw which broke off in the hole (see Oct26 entry) spent the morning doing that with no luck so moved on to thefirst dry assembly of the front deck with the fabricated components. Front deck tip up panel cover assembled , fitted then match-drilled and deburred. Canopy bubble fitted in position with all the frame components in place to mark the first markings for the 'big cut' of the perspex in two at the cabin frame center line. A couple more fits and double checking to get this line 100% located tommorow so that we can cut next week!
Front canopy deck assembled and match-drilled and deburred
Cut line located with proper fit of canopy, 1st of many fits to be sure before cutting.
