Brief Description: Panel design made up and more parts fab
Drew up digitally the panel outline and layout at 1:1 scale for print and output to .DXF and .DWG autocad formats. Panel template made up from foamcore material. Fabrication of parts for work started on the front deck area. Various brackets, angles, and plates shaped, cut and formed for assembly of deck and tip up hinge points and release system.
