Brief Description: Built a platform and began assembly of boost pump.
Design, cut and assembly of a custom platform from workshop wood for working on and in the now raised airframe. The simple design allows the platform to be used on either side of the cabin,allowing access to the inside, the front and top of the aircraft as well as to the empennage. Recieved a parcel of bits today including the long awaited boost pump kit and the custom stick grips, as well as the stock ally tube for the final fuel lines installation. After unpacking and inventorying the contents I was able to mock assemble the pump with some reference to pictures online and given some time reading over the accompanying material and diagrams.
