Brief Description: Continued RW re-skinning...collected contrl surfac
Continued re-skinning the Right wing as described previously, row by row and then across at the top and then across at the bottom, replacing worn holes with 'oops rivets' a size larger working from root to tip.
Also went along to the painter to collect our newly completed control surfaces (urgently required to install the wing tips and finalize the wings so they too can go for paint), H-stab and V-stab, all final coated in a brilliant (Arctic) gloss white which was impressive to see but I feel there is much to be done still in that the finish was in my opinion less than perfect with the white bringin out every imperfection.
