Brief Description: More riveting, lamp assembly, RW tank cover plate
To avoid further rivet work with the horrible head (having not yet received the swivel head) I continued work on the lamps and completed the4 VA-194 parts and began assembly of the L and R units with the lamp bulbs supplied.
Also trimmed and cleaned the RW tip lense cover as per the completed Left detailed some weeks ago. The various components of the lamp assemblies were prepped and primed.
Also finalized the RW tank cover plate and sender unit assembly as per the LW, when I finish up the rivet work on this wing I will lay it on the bench and secure the plate and sender in place on the tank and seal and finalize the tank as per the LW.
