Brief Description: Protective edging, shroud and frame adjustment and
Continued edging the sharp metal edges of the airframe with a protective sheath I made up from fiberoptic cable system lines. I trimmed the length to fit the edge then pulled the pipe along a blade in the vice to slit it along it's length.
After some advice I re-fiotted the canopy frame and shroud and used the methods advised to 'pull' the frame into shape and into position now that the hinges were drilled, I was struggling to close and even the gaps of the skins and the frame to the fuselage sills bu eventually got a good fit.
