P.S**This will be an experimental entry in that i am going to try out a much shorter explanation of work done:
I started then completed all work on the slot in the wall of the fuselage
I then installed the latch mechanism in place, then installed the parts up to the weldment which was also installed in it's bearing blocks in place on the rear spar buklhead.
Made up new improved wheel chocks for the workshop.
