Brief Description: right side of firewall was bonded and sealed and l
The right side of firewall was bonded and sealed the previous day and left to cure overnight with clecos and clamps, now did the same to the Left side and made sure to seal up all gaps and holes and joins for an airtight firewall. Entire assembly left to cure for 48 hours. Re-installed both sticks and control sticks assembly and after priming and cleaning the control rods inserted both large and small rod back in place in the cabin and fuz. Final riveted the center brace in the rear cabin to the baggage bulkhead. Researched then made the right hadn/passenger control stick modification, a twist and lock system was devised and a simple screw and pin fixed to the male end and an 'L' slot in the female produced good results but was somewhat less than secure so after dicussion an AN3 bolt and nut right through both was the solution which works well and is 100% secure - can also be removed without too much fuss.
